Results 1 to 4 of 4
Thread: 348 HEADLIGHT ADJUSTING "HELP REQD"
    Jun 2007
    Nr Glasgow
    Zak
    825
    Default 348 HEADLIGHT ADJUSTING "HELP REQD"
    The lights were taken out of my 348 for paint work and have now been put back in. The problem is that there is that one light sits higher than the other. Can anyone please tell me how you adjust them.
    Also are they adjusted in the open or close position ?
    Are there any pics on the forum showing how to do this ?
    I would really apreciate your help. It's the first F car that the Body shop have done.
    I have tried searching the threads but couldn't find anything.
    Oct 2007
    Trowbridge UK
    Chris Honeywell
    633
    OK had similar problem with mine this week just gone
    easier to do it with the lights up and u only need a 10mm spanner...
    POP the bonnet put the lights up and have a look at side of the light, you will see the motor with like a small "crank" and you will see a threaded bar which goes from the motor to the headlight (joints on each end)...
    Now to adjust the passenger light (as i had to do)
    loosen the 10mm locknuts which are on each end of the bar few turns fiddly but can be done
    then (passenger side) using the same 10mm spanner wind the threaded bar using away from your body to lower the light and towards yourself to raise it...
    You should be able to see the headlight raise and lower mm by mm
    http://img.photobucket.com/albums/v4...P1010055-1.jpg
    Oct 2007
    Trowbridge UK
    Chris Honeywell
    633
    All this is assumming that the motor arm is in the correct place
    Also when the light are up are they both the same height??
    Jun 2007
    Nr Glasgow
    Zak
    825
    Thanks, very much apreciated.
  1. Club Scuderia Owners Club!
    By Gimme Fuel in forum Ferrari Talk
    Last Post: 18-07-2012, 12:09 AM
  2. Is the 348 a good Ferrari ?
  3. 348 Mag.is off for printing!!!!!!!!!!!!!
    Last Post: 24-02-2007, 11:32 AM
  4. For all 348 owners and enthusiats
    Last Post: 11-08-2006, 08:56 AM
