Results 1 to 4 of 4
Thread: 328 Heater wiring problem, 328 electrical expert required!!
    Aug 2007
    Burton On Trent
    Darren
    39
    Default 328 Heater wiring problem, 328 electrical expert required!!
    I have a problem on the wrining on my 328, on the passenger side the heater controls do not work. I did know when I brought the car but thought it was the switch, I have checked the switch and motorised valves and they work.
    If I run some cable from the connector in the tunnel to the valve motor it works fine so there must be a break in the wire or a plug some where that I don't know about.
    Does any body have any ideas, its very hard to see where the cables go I am guessing that there is a plug I haven't found or the wire has been cut by acciendent (maybe when an alarm was fitted)
    Has anybody got any ideas.
    Iain
    7,173
    Quote Originally Posted by Das View Post
    Brrrrrrrr 20 year old Ferrari electrics I'm afraid I can't be of any help, everything in mine works (touch wood) & so I havn't really had to delve into that area
    Aug 2007
    Burton On Trent
    Darren
    39
    Now fixed.
    Bad contact on connector behind fuse/relay board.
    Took some finding!!.
    Iain
    7,173
    Now fixed.
