Results 1 to 10 of 13
Thread: New tyres
    Halifax,
    ian
    1,651
    Default New tyres
    Looking for some new bridgestone tyres for the 348, there was a link on here once for ferrari tyres,(can't find it) can anyone help ??
    Ta
    Halifax,
    ian
    1,651
    anybody had any knowledge of these tyres for a 348 ?
    Turanza ER 300 215/50 R17 91W supposed to be by Bridgestone 118 each
    19,101
    Sound not quite right - Potenza seem more appropriate
    http://www.ctyres.co.uk/tyres/bridgestone.php
    London/Kent
    Henry
    215
    I just ordered a whole new set of boots for the F40 after Brands last week and have sourced them through Steve who was at the track day:
    Simply Tyres - 07737741634
    Very impressed with the price and service - especially as I was told the PZero was like gold dust to get hold of
    Mar 2008
    Malta - at the pub mostly
    Xmun
    2,513
    I would really really steer clear of the Bridgestones.
    May I recommend the TOYO T1R's, Michelin MV3A Pilot or the Pirelli PZERO
    Actually you could just spread butter around the alloys and they would grip better than the bridgestones!!!
    Had them on my MX5 sport and on my S2000 and in both cases changed the tyres after less than 2000 miles cos it was frustrating - handling totally different after. Just to give you an idea a corner with the bridgestones in the S2000 was a challenge @ 40mph. Same corner with the T1r's @ 68mph without one single step out.
    t1grm is offline It's basically an old car with a stripe - The Ferrari Challenge Stradale Club Member
    ii
    7,772
    Quote Originally Posted by ACE View Post
    Is that just a rough guideline Simon?
    Mar 2008
    Xmun
    2,513
    Quote Originally Posted by t1grm View Post
    No G! The S2k has a lurvely massive digital readout
    Murph7355's Avatar
    Here there and everywhere
    Murph
    14,313
    Bridgestone SO1s were fine on my 355. Easily as good as the PZeroes it had on when I bought it. Bridgestones also work fine on my Aston.
    Much will depend on how the car is set up IME. I believe the 355 setup is different depending on the tyres it has - a sticker on one of the door jambs notes what tyres they had out of the factory. As a minimum, pressures are different. Other settings may also change.
    Bridgestones wear well IME. Better than Pirellis.
    Nov 2006
    st.neots
    steve newman
    14
    Must say fitted a set of bridgestones to my 348 and a vast improvement over the p zero,s.The tram linning on rutted roads disapared so to did the aqua planing in the wet.much more stable under heavy braking.Far better grip and at just over 500 the set not bad price
    Mar 2008
    Xmun
    2,513
    One thing that we are not taking into consideration is the quality of the tarmac. The road surface in the UK is much more grippy than here in Malta so it would make a substantial difference.
    As already mentioned, the Bridgestones are a harder compound and therefore wear less - but here in Malta we need the softest compounds possible.
  1. 360 with different Tyres in front and rear
    By Kid in forum Ferrari Talk
    Last Post: 06-08-2008, 10:12 PM
  2. Tyres - road use after track use
    By Jersey308 in forum Technical Q & A
    Last Post: 05-08-2008, 10:33 AM
  3. 550 Tyres
    By Georginetto in forum Technical Q & A
    Last Post: 06-03-2008, 01:23 PM
  4. Cheap Tyres
    By actioncandy in forum Technical Q & A
    Last Post: 12-09-2006, 07:42 PM
