Page 1 of 232 1231151101 ... LastLast
Results 1 to 10 of 2314
Thread: 348 DIY "Restoration"
    3,373
    Default 348 DIY "Restoration"
    As some of you know I recently bought "348 KYD" from the Isle of Man so I thought I thought I'd show you what I've been up to.
    http://www.clubscuderia.co.uk/forum/...&highlight=kyd
    First thing I like to do when I get a car is to give it a thorough clean so I can get to know it and find out all the little niggles that need fixing.
    After giving the car a regular wash I wanted to get the car scrupulously clean so using a product called Iron-X that removes bonded contraminants I covered the car
    After a few minutes any iron based contaminants start turning purple - you can just about make them out in this pic
    Just to jolly things along I used a small brush to agitate the product especially around the badges and the grill louvres
    Once its done its work just rinse off with water and you should have a pretty clean car
    3,373
    After decontaminating I clay barred the car using a Bilt Hamber mdium clay bar with some megs last touch as the lubricant (you can use water but I find it easier wiith last touch)
    http://i68.photobucket.com/albums/i2...pg[ATTACH]
    Left me with one very dirty clay bar
    3,373
    Now that the car was free of metal bonded contaminants I next clay barred it using a Bilt Hamber medium clay bar and some megs last touch as the lubricant (you can use water but I prefer the megs)
    Name:  Clay Bar 001.jpg
    Name:  Clay Bar 002.jpg
    Name:  Clay Bar 006.jpg
    3,373
    After the car was clay barred I started machine polishing it with some 3M fast cut followed by a lighter cut (more pics and details when the car is all done). However, after doing the bonnet what really let it down was the air intake grill looking a bit faded
    Name:  Bonnet Vent 001.jpg
    First of all I used panel wipe from the local paint factors to get rid of any polish etc then used G-Techniq permanant trim restorer applied with cotton buds (very boring) to wipe over each little vent - cant recommend this stuff highly enough (despite its high price) as it lasts over a year and leaves plastic like new. In a couple of days Ill be doing something else to it too to make it really black! ;-')
    Name:  Bonnet Vent 002.jpg
    Name:  Bonnet Vent 003.jpg
    3,373
    The front grill area was looking a little worse for wear as the actual grill was faded and the black behind it was stone chipped.
    Name:  Front Grill 001.jpg
    My preferred metal polish is Belgom which I used in conjunction with an electric toothbrush to get into all the nooks and crannies
    Name:  Front Grill 002.jpg
    After a few secs the polish goes grey as it attacks the dirt
    Name:  Front Grill 003.jpg
    I'd got some paint mixed at a paint factors rather than get a touch up pen - that way you can spray just enough into the cap - let it go off a bit then use a small brush/tooth pic/cotton bud to paint blobs on chips etc
    Name:  Front Grill 004.jpg
    Offending chip that got "blobbed"
    Name:  Front Grill 005.jpg
    Any chips on the black backgrouns were blobbed with some matt black engine paint which is ideal for small black touch ups as it blends perfectly and you cant see where its been painted. The grill wa treated to the G_Techniq permant trim restorer and then screwed back in place - so you dont lose the screw I put a smidgeon of tape round it and then as soon as it grips you can pull it away and discard the tape.
    Name:  Front Grill 006.jpg
    The covers at the side of the lights were painted with same paint and to save removing them a piece of paper can easily be slid between the light and bodywork and then the cover painted.
    Name:  Front Grill 007.jpg
    All done and now looking like new :-) Just got to sort the lights out and touch up all the stone chips on the bumper
    Name:  Front Grill 008.jpg
    3,373
    And now to the back. Despite a good wash the lights looked dirty through the grill so I took out the 2 screws at each end of the grill plus the 2 in the middle and took the grill off.
    After wiping most of the dirt off with panel wipe I then machine polished the lights using maguires plastix-X. You can see the difference between the lens closest to the camera (uncleaned) and the one furthest away after a polish. The reversing lamps are particularly noticeable.
    Name:  Rear Lights 001.jpg
    Close up of the polished lense
    Name:  Rear Lights 002.jpg
    The screws were grotty on mine and so I bought a pack of replacements from Halfords (slightly cheaper than Ferrari!!)
    Name:  Rear Lights 005.jpg
    As you can see identical
    Name:  Rear Lights 006.jpg
    And in place
    Name:  Rear Lights 007.jpg
    Again trim was treated to G-Techniq before all being reassembled
    I'm most probably going to revisit this area to do the blacking properly as not happy with it at moment.
    19,104
    Can I have my toothbrush back please
    Sep 2009
    China
    Scott
    266
    Car looks good with the 360 alloys
    Sep 2006
    Chandlers Ford
    Phil Worrall
    1,655
    I can only see the last two photos
    P
    19,104
    Will all this fine work include levelling the front number plate ?
  1. 348 steering wheel local "clunk" noise
    By ricbowling in forum Technical Q & A
    Last Post: 14-07-2009, 08:37 PM
  2. 348 HEADLIGHT ADJUSTING "HELP REQD"
    By Zak348Gtb in forum Technical Q & A
    Last Post: 07-11-2007, 09:37 AM
  3. "older" 348 model (dis)advantages
    By RacingSnake in forum Ferrari Talk
    Last Post: 07-09-2007, 12:48 PM
