Page 231 of 231 FirstFirst ... 131181221229230231
Results 2,301 to 2,309 of 2309
Thread: 348 DIY "Restoration"
  1. #2301
    3,363
    Yes 100% 1 man job.
    You do need the silicone pipe with the slit in though!
    Has worked perfectly every time for me and I do the brakes the same way.
    You know you have teh pump on as you hear it buzz for up to about 30 seconds (longer and there is something wrong according to wsm)
  2. #2302
    3,363
    Never really liked the after market aluminium rings on my dials so pulled them off the central console but never got round to doing the speedo binnacle. Anyway, I do prefer the look of the 355 silvered gauges and after watching a program about a canning factory I thought I'd try something similar!
    I thought I'd practice on the end of a jar so taped some old wallpaper down to the floor, sprayed it with silver paint and then carefully place teh jar on the paper (briefly).
    Looked good enough for me :-)
    The target....disassembled the gauges from the console and the bezels from the gauges
    Progressing onto grease proof paper now - all very serious!
    Sprayed the greaseproof paper quite generously with paint
    And then very gently placed the dial gauge on rocking it ever so slightly
    Not bad for first attempt. As it was drying I used a bit of panel wipe to smarten up the inner edge.
  3. #2303
    3,363
    Strangely they just didn't look right then by chance I read a post about a 355 and it showed that the bezels are are painted not just on the tips but down the sides which I was surprised about so I taped up the insides and tried spraying the outside too
    And with tape removed
    And back in the panel
    I think I like them :-)
    I did my best not to take too many bits apart to get the console panel out
    One thing I did try and fix is to put a tiny bit pf bathroom sealant on the underside of teh gear shift below as it keeps folding into the gear shift gate - grrrr!!!
    With everything back in place - they actually look far better in real life (IMO)
    Comparison of my painted gauges vs the after market aluminium bezels (which are far too thick IMO)
  4. #2304
    746
    Blue peter has nothing on you
  5. #2305
    May 2019
    Worcester
    Steve R
    18
    Looks good. Well worth the effort.
  6. #2306
    3,363
    Just had my email calendar reminder through.....got the car 8 years ago today!!! :-)
    About 20 mins into ownership I took a photo with the Laxey Wheel for "import" purposes (didn't need it as it happens).
  7. #2307
    milkshaker0007's Avatar
    1,197
    i think they stand out better, draws your attention to them.
    nice one
  8. #2308
    3,363
    Cheers guys- I'm going to do the other gauges as son as I get a moment :-)
  9. #2309
    MalcH's Avatar
    11,573
    Looking good
  1. 348 steering wheel local "clunk" noise
    By ricbowling in forum Technical Q & A
    Last Post: 14-07-2009, 08:37 PM
  2. 348 HEADLIGHT ADJUSTING "HELP REQD"
    By Zak348Gtb in forum Technical Q & A
    Last Post: 07-11-2007, 09:37 AM
  3. "older" 348 model (dis)advantages
    By RacingSnake in forum Ferrari Talk
    Last Post: 07-09-2007, 12:48 PM
