Page 1 of 8 123 ... LastLast
Results 1 to 10 of 75
Thread: Putting car away damp?
    10,948
    Default Putting car away damp?
    Quick question. Just been out in my 348 for a spin then given her a good wash and dry. Problem is I've got a bit of a dusty garage so use a soft fabric car cover. Do I leave this off for the car to dry properly (ie under and in nooks and crannies) or put it on to keep dist and grit off the car. Cover is obviously breathable, garage is dehumidified but not heated. Essentially dont want grit/garage dust on the paint, don't want to cause water to sit in nooks and crannies. Any suggestions?
    Terry's Avatar
    Northwich, Cheshire
    Terry
    2,917
    The best investment other than the car is to get a Carcoon.
    You can put the car wet in the Carcoon and it will dry it out and keep the dust off at the same time. It will also condition your battery.
    I can say it is the best accessory I have every bought.
    You can buy one from Stevew at CS prices.
    10,948
    Quote Originally Posted by Terry View Post
    Thanks mate, will bear that in mind. In the meantime, is it ok to put a soft fabric cover over a car that has been washed, then dried or do I need to leave it totally open to the air?
    Terry's Avatar
    Northwich, Cheshire
    Terry
    2,917
    I would let it dry first. A leaf blower works quickly and does a good job but avoid the dust. (do it outside)
    10,948
    Thanks mate.
    10,948
    Another quick question. What should I use to dry the car in the first place. I've got a Swissvax micrfibre drying towel, but have been a tad underwhelmed by the result, doesn't seem to do as published and leaves streaks. Originally had an unopened synthetic chamois but this came away feeling waxy (another couple of layers of Swissvax Scuderia later !!!.) hence buying the swissvax towel. What would you sugest? I'm washing with swissvax car bath and use their quick finish and Scuderia wax.
    Apr 2008
    At work-mostly
    Mark Hannaford
    482
    Get yourself a Miracle Dryer from Clean Your Car. Large microfibre towel that does an amazing drying job.
    10,948
    Quote Originally Posted by Mark456M View Post
    Thanks mate, will do.
    Kings Hill, Kent
    2,504
    I take my 348 for a short drive after washing, and get the engine hot. That tends to dry out all the water/dampness.
    It's then parked in a dehumidified garage, and I find the engine's heat takes hours ot dissipate. I then cover the car 3-4 hours after parking. I'd leave the cover off a little while if I were you.
    My garage is not dusty though.
    Carper Mike
    477
    Thumbs up
    If you want to go the full nine yards then install a de-humidifier inside the carcoon / air-chamber on a permanent drain to a bucket outside the chamber. Run it 24/7 because the humidistat will mean it is running fan only most of the time = cheap as chips as not trying to de-humidify the entire ( poorly sealed ) garage
    Maintain approx 50 - 55 % RHD inside the chamber ( you can buy a cheap RHD digital display and put that in chamber also for peace of mind ).
    Main benefit to me in this set up is i have not experienced a single electrical / sensor issue ( + of course car kept in perfect condition bodywork wise ).
    Cheers ... Mike.
  1. Why is inside of my wall damp?
    By kryten22uk in forum Lounge
    Last Post: 07-12-2010, 08:04 AM
  2. Replies: 1
    Last Post: 07-10-2010, 10:33 PM
  3. 430 - Damp in the boot
    By kryten22uk in forum Technical Q & A
    Last Post: 26-04-2008, 06:24 PM
  4. Putting the car to bed for the winter
    By Juke 360 in forum Car Cleaning and Detailing
    Last Post: 03-11-2006, 01:12 PM
  5. Putting my car away
    By Chris Foster in forum Ferrari Talk
    Last Post: 06-12-2005, 11:53 AM
