Page 1 of 5 123 ... LastLast
Results 1 to 10 of 47
Thread: F430 Exhaust valve bypass
    Surrey
    Simon
    245
    Default F430 Exhaust valve bypass
    Hi - am sure this has appears on the site hundreds of times...but have tried searching and haven't found the answer.
    If anyone could send me a link, would be grateful.
    Am interested in bypassing the exhaust valve on my 430, allowing a louder echaust sound at lower revs/on idle
    I believe it is a simple job, disconnecting 2 pipes, and covering up the ends....I just don't know which pipes!
    Can anyone assist?
    Dec 2009
    Slapshot
    513
    There should be a small diameter rubber hose connected to the red-circled area in the photo below. Disconnect the hose and stuff a golf tee in the end. Then do the same with the valve on the other side of the car.
    Surrey
    Simon
    245
    Thank you very much indeed for that response and pic...perfect - can't wait to try it now!
    Thank you
    Dec 2009
    Slapshot
    513
    Quote Originally Posted by Siy View Post
    Thank you
    I've been running mine 'unleashed' like this for a year now as it sound like a Ferrari should ALL the time. Particularly when starting, at tick over, and pootling around town.
    An additional benefit is that you don't get the black staining on the bodywork underneath the outer exhaust tips like you do with the vacuum hoses connected.
    Apparently the only downside is a slight loss of torque at low revs, but I've never noticed.
    Surrey
    Simon
    245
    Think there is probably enough torque there anyway!
    Jun 2009
    Gareth
    166
    What are the jubilee clips and foil tape for on the silencer? Presumably they are not connected to the valve opening mod
    Dec 2009
    Slapshot
    513
    Quote Originally Posted by big g View Post
    It's my solution to stop the white insulating powder escaping from the muffler and coating the engine bay. It's a common problem on the F430 and 360 Modena (apparently).
    Surrey
    Simon
    245
    Does that work? If it doesn't escape there, where does the white powder go to?
    Dec 2009
    Slapshot
    513
    It stays in the muffler body where it belongs.
    Surrey
    Simon
    245
    ahaaa.....genius!
  1. 355 Exhaust bypass valve refurbishment
    By rodredmr2t in forum Technical Q & A
    Last Post: 08-08-2013, 05:19 PM
  2. F355 Standard exhaust bypass valve noise change
    By Mario149 in forum Technical Q & A
    Last Post: 13-05-2010, 05:48 PM
  3. 355 Exhaust bypass valve, vacumn failed
    By smiley in forum Technical Q & A
    Last Post: 07-10-2009, 10:40 PM
  4. 355 exhaust bypass valve
    By Ade in forum Technical Q & A
    Last Post: 04-11-2005, 05:28 PM
