Results 1 to 10 of 10
Thread: F430 Fuel guage
    Souffampton innit
    Geoff
    1,253
    Default F430 Fuel guage
    Went from Southampton to Lulworth Castle and back the other day and was pleasantly surprised the fuel gauge only showed two increments depleted (from a full tank). Admittedly we were only pootling along due to heavy traffic both ways but nonetheless, I thought it quite good!
    However, when I got home, turned it off, washed it and then put it in the garage, the gauge showed 1 increment under half. Anyone else have false reading whilst on the move or is this normal (can't be surely?)!!
    Happiness is a full tank and an open road - unless you live in the UK of course......
    Oct 2010
    Surrey
    Stuart
    1,842
    Only ever happened on track, still I used to alway trip the counter on a fill up as the miles don't lie.
    phillg's Avatar
    phillg is offline Looks like a 308 to me? -The Ferrari 288 GTO Club Member
    Nov 2006
    Dorset
    Phill Grimshaw
    2,640
    Geoff,
    I reset the trip after each refill,and will achieve 360 miles on a full tank.The low fuel light will come on though.
    Parking on even a slight slope will add or delete bars.sometimes several bars can disappear in one go.(or even come back)
    Hence I go by the miles i've covered.
    Spider,or coupe? Just get one of each.
    Souffampton innit
    Geoff
    1,253
    Thanks Phill & Revhappy, I guess that is the best think to do but it's still a bit disconcerting!
    Apr 2011
    Neil
    279
    I had issues with the fuel reading on my 430, below half a tank the gauge was unreliable, jumping from low to halve full each time you started the car.
    Two new fuel sensors, 1 in each tank solved it.
    Neil
    Jul 2007
    Hertfordshire
    Lisa
    44
    My 328 fuel gauge swings wildly whilst going around corners. Its as if there's no damping on the gauge, which I think most cars have.
    I'm not sure if its supposed to be like this or not?
    Apr 2011
    Neil
    279
    Not sure about the 328 specifically, but no, fuel gauges should not do this. Older cars may be different, but there should be baffles in the petrol tank to stop the fuel moving freely in the tank and the fuel sender(s) should even it out.
    You are describing a very similar problem to what I had, I also had issues when the fuel level was getting low, the gauge moved frequently up and down, noticeable also when I went around corners. The fuel senders were at fault.
    Neil
    6,647
    Quote Originally Posted by Freddie View Post
    They (328's) all do that Sir
    phillg's Avatar
    Nov 2006
    Dorset
    Phill Grimshaw
    2,640
    I agree,my 328 was like it.
    Jul 2007
    Hertfordshire
    Lisa
    44
    That's useful to know, thanks - I've been wondering over the last 10 yrs if it should do that!
    I've also noticed you shouldn't fill up to the top of the filler pipe - fuel over flows all over the petrol station forecourt.
  1. F430 what type of fuel is best?
    By Redcarrick in forum Ferrari Talk
    Last Post: 12-03-2013, 04:10 PM
  2. Fuel question F430
    By steelej in forum Ferrari Talk
    Last Post: 29-12-2010, 12:50 PM
  3. Paint Thickness Measuring Guage
    By Bruce in forum Car Cleaning and Detailing
    Last Post: 25-03-2010, 12:52 AM
  4. Mondial 8 fuel guage
    By grahamjazz in forum Technical Q & A
    Last Post: 28-04-2008, 08:58 AM
  5. 348 Oil Temp Guage packed up
    By Siban in forum Technical Q & A
    Last Post: 30-07-2006, 09:14 PM
