Page 19 of 21 FirstFirst ... 91718192021 LastLast
Results 181 to 190 of 205
Thread: 328 Tinkering
  1. #181
    Dec 2014
    28
    Started the machine polishing process today. Only had a couple of hours so decided to focus on the rear of the car. I will tackle the doors, wings and bonnet another time.
    The paint on the rear deck is very, very thin and is single stage (no clear coat) so I had to be extremely careful. For this I used a dual action polisher, which is generally safer than rotary. The rear deck only had minor swirls (more visible in direct sunlight) so very light compound is all that's required.
    After removing all existing polish with GTechniq panel wipe, I ran two stages on the rear deck. First was with Menzerna Power Finish 2400 followed by Menzerna Super Finish 4000. Both with a black Meguires 7" finishing pad.
    The paint on the rear quarter panels is much thicker multi layer and clear coated but I chose to run the same process as correction required was minimal.
    For paint measurements I use a Paint Detective PD8 gauge.
    Once the rear and rear quarters were complete, I laid down two layers of my posh Swissvax carnauba wax.
    All in this took my a couple of hours. Really happy with the result. Finish is now flawless. iPhone pics don't really do it justice but here you go...
    Now need to find some time to do the doors and front of car.
  2. #182
    milkshaker0007's Avatar
    1,186
    That's stunning
  3. #183
    Herts
    Graham
    584
    Thanks Paul. 👍
  4. #184
    1,186
    Hi graham
    What type of polisher have you been using ( have you a pic)
    Thanks
  5. #185
    Dec 2014
    28
    I've used two machines on my Ferrari. Mainly I've used this. It's a Meguires G220 v2.
    It's ideal for the amateur / occasional user and because it's dual action it's pretty safe. It can be used for all but the most severe paint correction and gives a mirror finish you will never achieve by hand - assuming it's used properly and with appropriate compound and pads.
    I used it to correct some minor imperfections on my rear deck. The paint is so thin I didn't want to risk taking too much off.
    I also have a Flex rotary as I'm doing more and more of this work now for friends and club members etc. This is easier to work with and reduces compounding time significantly. It's very powerful though and needs much more experience than the Meg's DA but the results are even better.
    I used this on the rear quarter panels and rollover bar/panel and will use it with the same two stage compounds as above on the rest of the car where the paint is thicker and is clear coated.
    Pm me if you want some more detailed advice. I've unwittingly become a bit nerdy on this subject as you've probably worked out by now - happy to share.
    Cheers.
  6. #186
    1,186
    Thanks for the info graham
  7. #187
    Nigel Jeffery Specialist Cars's Avatar
    Nigel Jeffery Specialist Cars is offline Only 37 known common faults - The Ferrari 355 Sponsor
    Nov 2011
    Hertfordshire
    Nigel Jeffery
    1,034
    Great stuff Graham , Nick Cartwright and myself were chatting at the end of last week and neither could believe that its 2 years since you bought the car as both of us said we still look so young
  8. #188
    Dec 2014
    28
    Finished most of the paintwork today. Surprising hard work but well worth the effort. Blinging now
    Lots more to do but will down tools now until I get back from Le Mans.
  9. #189
    995
    The paint looks really nice. Good job.
  10. #190
    Herts
    Graham
    584
    Thanks Nick. 👍
  1. 328
    By markst in forum Ferrari Talk
    Last Post: 24-06-2010, 12:23 PM
  2. Smokey 328
    By 328WYD in forum Technical Q & A
    Last Post: 19-09-2009, 08:18 PM
  3. 328
    By F355GTS in forum Galleries and Members Cars
    Last Post: 24-03-2009, 05:00 PM
  4. Replies: 3
    Last Post: 13-11-2007, 01:06 AM
  5. 328 Value?
    By F355GTS in forum Ferrari Talk
    Last Post: 07-11-2007, 07:37 PM
