Page 70 of 70 FirstFirst ... 2060686970
Results 691 to 696 of 696
  1. #691
    Nosevi is online now There's an outside too? Where? Super Moderator
    10,952
    ECU update. Original pair now back on the car and working fine. No CELs or codes. Hopefully will stay that way. Ive had another unrelated electrical fault on the other bank but that is sorted now. Bad connection as usual.
    Good news
  2. #692
    United Kingdom
    GQ
    749
    Also good news knowing repairs can be carried out successfully. Its probably only a matter of time for the rest of us! . Thanks Nick.
  3. #693
    1,001
    Default Phase sensor replacement.
    Simple enough job to replace the phase sensor. No fault with it only that its its old. Connectors have been known to crumble.
    The sensor is mounted in the housing on the back of the 1-4 bank inlet cam. Easier access with the airbox removed. Unplug the wiring loom on the LHS. Three 8mm nuts secure the housing and one 8mm nut for the wiring clamp . Oil can leak into the housing from the seal at the back of the camshaft so if present the seal should be replaced. The housing is nice and clean here. There is a timing disc on the back of the cam held by three screws and located on a dowel for correct orientation. The sensor is secured to its mount by two 3mm Allen bolts. All pretty simple and strait forward reassembly.
Size:  44.8 KBName:  20190208_135453.jpg
Size:  61.9 KBName:  20190213_111456.jpg
Size:  37.6 KBName:  20190213_110849.jpg
Size:  79.9 KBName:  20190209_142131.jpg
Size:  99.5 KBName:  20190213_111127.jpg
Size:  335.7 KBName:  20190209_141800.jpg
Size:  151.3 KBName:  20190209_144459.jpg
  4. #694
    764
    If anybody is after O2 sensors the order I put into eurocar parts has worked a treat! Bosch sensors turned up; 50 each shipped with their latest discount code! Much better than all the normal sources for Ferrari parts at circa 200 each.
    I even popped Ferrari 348 in as the make and model. I did cross check the part number against the Volvo that has the equivalent sensor to double check I was ordering the correct part.
    Happy days
  5. #695
    3,532
    Happy days
    I've used them for years on my daily runners and buy 360 discs and Bosch parts from them.....Try carparts4less also. Same company but usually a bit cheaper without the silly 50% discount codes onto inflated prices
    See the 360 coil thread for where not to order from
  6. #696
    764
    Thanks Mike, didn't know about carparts4less.
    I also use them for my daily (BMW parts are almost as stupidly priced as Ferrari!), but often get brakes from EBC Direct as well. Lots of choice...but with care!
