Results 1 to 8 of 8
Thread: 348 centre dash heater vent resto.
    995
    Default 348 centre dash heater vent resto.
    Decided to tackle my centre heater vent today. Not a pleasant job by any means. Here are some photos of what Ive done so far.
    Before starting. Bit dusty as has been sitting around the prep area for a few days. Everything sticks to that stuff.
    Vent stripped down to component parts. Most of anyway. Not to difficult.
    Try removing as much of the sticky with a blade or scraper as below as this stuff tends to smear and this makes it easier in the long run.
    Ive seen all sorts used and recommended for the removal of the sticky and tried all sorts myself but white spirit seems as good as anything if not better. Works for me. I used the cotton buds for awkward areas but they don't last very long so you will need quite a few.
    After scraping as much paint off the vent as possible I then soaked a duster with the spirit and passed it through the vent slots and rubbed away until the paint was gone. Do this a few times for a better result.
Size:  52.7 KBName:  DSCF8875.jpg
    This is as far as Ive got for now so will post some more pics as I go on. You can see the top of the vent I'm working on has come out fine.
    Angelis's Avatar
    London/Essex
    Sy
    17,009
    Would it be possible to carbon dip it?
    995
    Quote Originally Posted by Angelis View Post
    Don't see why not. Seems like you can do anything else. I wouldn't myself as I'm not a big lover of carbon trim in older cars and I prefer an original look. Personal preference again.
    995
    Some pics of how I took the vent apart. Things do seem very tight and difficult to strip but it can happen.
    First is the main air flow control. This is quite tricky but with the two screwdrivers shown you have to manipulate it out of its locator holes and the stop slot while keeping a firm pressure on the control and pushing towards the white dot. The larger driver clears the bottom locator hole and the smaller pops out the guide. Hopefully then it will pop out of top hole which you can't see. Keep the pressure on at all times if you can. It will only come out this way and will slide off the flap control rod as it does. The plastic was reasonably compliant and I was able to bend it enough without any breaks. Same for the other side. Worked for me.
    Next are the main vents. I used an allen key to disengage the hinges but any hook device will do. Lock in behind the grill and pull hard and it should start to come out. Go to the other side of the grill and pull there too. Hopefully both hinges will have disengaged enough for it to come out now. In retrospect It would have been easier for someone to hold the vent and pull both ends at the same time. Ive put some pics of the hinges so its easier to see what you are up against. Pretty self explanatory though.
Size:  57.3 KBName:  DSCF8934.jpg
Size:  48.5 KBName:  DSCF8936.jpg
Size:  46.2 KBName:  DSCF8938.jpg
    More to come.
    995
    Here is the air direction flap assembly behind the vent. This will be sticky too so needs cleaning and painting. I found taking the outside flaps off first gives you better access to the centre one which has the control knob on it. Its easier to get out if you push it round until flat as pic shows. There will be a bit of resistance but it will pop past the stop.
    You can then take it out of it mountings carefully. Reverse operations to assemble. The flaps will only fit one way.
Size:  51.3 KBName:  DSCF8920.jpg
Size:  42.5 KBName:  DSCF8922.jpg
Size:  53.3 KBName:  DSCF8923.jpg
Size:  46.6 KBName:  DSCF8924.jpg
Size:  51.9 KBName:  DSCF8928.jpg
    995
    When all painted and fettled you can reassemble quite simply. Note which way the vents came out (top and bottom).They will slide in with a firm push and lock to the hinge pins. Same for the control levers but take your time and try not to force the flap control lever fork to much in case you snap it. Below is the finished article. Im quite happy with it. Also a photo of one of my side vents which I have done already. I had the white decals cut out of vinyl. At first I tried 5mm but they looked too big so these are now 4.5mm. Whats the opinion? I can still change them before I matt laquer them in. I finished the vents in Plastikote Super Matt. Lots of light coats over an hour period. Sticky no more.
Size:  66.4 KBName:  DSCF8983.jpg
Size:  55.7 KBName:  DSCF8978.jpg
Size:  55.7 KBName:  DSCF8988.jpg
    Aug 2013
    Oxford
    Jason Boud
    116
    Looks the dogs b's to me
    Apr 2013
    South Coast, Hants
    Carl
    1,466
    great effort
  1. 348 Drivers side heater vent.
    By Pangea in forum Wanted
    Last Post: 30-04-2014, 06:50 PM
  2. 348 vent removal
    By Yorkshirelad in forum Technical Q & A
    Last Post: 27-07-2012, 12:22 PM
  3. Air vent ./ centre console removal F430
    By Siy in forum Technical Q & A
    Last Post: 27-07-2012, 06:21 AM
  4. 348 Vent Heads Connection Pipe
    By dasherdiablo1 in forum Technical Q & A
    Last Post: 16-01-2011, 12:21 AM
