Page 3 of 65 FirstFirst 123451353 ... LastLast
Results 21 to 30 of 645
Thread: F355 Spider Repair
  1. #21
    Nov 2006
    Wigan
    Gordon Davidson
    23
    Hi Terry
    Great to see you have started the resurrection of my poor car! It is in good hands now, I really did not want my stupid accident to be the end. Still wish it never happened, really miss her!
    I can't wait to see the results of your work. Started saving now so I can buy her back!!
    I will be watching with great interest!
    Gordon
  2. #22
    ronrob's Avatar
    Oct 2007
    Var, S.E. France
    Ronald Brown
    863
    The Doctor has started work. Good on you Terry. I was convinced that you were going to go for a 360 or even a 430. If we know you (and we do) you will not stop at sorting out only the damage. Every nook
    and cranny will get the treatment.
    All the best,
    Ron
  3. #23
    Terry's Avatar
    Northwich, Cheshire
    Terry
    2,914
    Quote Originally Posted by GordonD View Post
    Hi Terry
    Gordon
    Hi Gordon, it will definitely not be the end, give it a little time and it will be well again!
    Quote Originally Posted by ronrob View Post
    All the best,
    Ron
    Thanks Ron, I was ready for whatever came along. I saw a couple of other cars but getting another 355 made a lot of sense as I have quite a few extra compatible parts lying around.
    I plan on stripping the interior first as I will be short of space in the garage when I remove the engine. All the spare corners in the house will be taken with interior parts, amazing how much space is required for removed parts. First job is removing the roof, a task for next weekend.
  4. #24
    Dec 2008
    Spain
    Howard
    392
    Terry
    If you come across that drivers side door window glass rubber gasket that you thought you may have in a box somewhere do please let me know.
    My 355 needs one bad.
    Howard
  5. #25
    Terry's Avatar
    Northwich, Cheshire
    Terry
    2,914
    Quote Originally Posted by lotusk View Post
    Terry
    Howard
    Will do Howard. I did have a good look round a few weeks ago and did not find it. I know that I would not have thrown it away so will keep a look out for you.
  6. #26
    Dec 2008
    Spain
    Howard
    392
    Quote Originally Posted by Terry View Post
    Very kind
  7. #27
    MalcH's Avatar
    11,521
    It's why I re-subscribed if I'm honest. Looking forward to seeing you and Jane soon. May try to get Mr Capner and his missus to join us.
  8. #28
    Feb 2006
    Kwang
    364
    Looking forward to reading your progress.
  9. #29
    Terry's Avatar
    Northwich, Cheshire
    Terry
    2,914
    Roof removal was the first task. It seemed to operate reasonably well but I had to motor the seats forward manually before the roof would stop beeping and open, will sort that out later.
    Name:  P1040302 (Large).jpg
    Name:  P1040299 (Large).jpg
    The main hinge point has three attaching bolts although only one is visible.
    Name:  P1040287 (Large).jpg
    The rear frame also has three bolts bolted into the top of the rear quarter recess. Only visible with a torch and mirror at this point.
    Name:  P1040294 (Large).jpg
  10. #30
    Terry's Avatar
    Northwich, Cheshire
    Terry
    2,914
    With the hinge covers removed, not much more could be seen regarding the attachment bolts, at this point I thought there were only two. (proved wrong later)
    Name:  P1040309 (Large).jpg
    Name:  P1040310 (Large).jpg
    Centre trim removed (easiest part of the job), two screws.
    Name:  P1040311 (Large).jpg
    The left side of the car contains the hydraulic distribution block. You can just see the two actuators that move the roof, the larger lower on and the small upper underneath a small cover.
    Name:  P1040312 (Large).jpg
    Name:  P1040313 (Large).jpg
    Name:  P1040314 (Large).jpg
    The pipework feeds underneath the carpet to the pump mounted in the centre of the bulkhead, there are also two lines from the left to the right hand side.
  1. F355 spider
    By Ton in forum Ferrari Talk
    Last Post: 08-02-2010, 06:50 PM
  2. F355 Spider gone
    By SESH in forum Ferrari Talk
    Last Post: 26-11-2009, 03:04 PM
  3. F355 spider
    By RossMardell in forum Ferrari Talk
    Last Post: 11-05-2009, 03:28 PM
  4. F355 Spider Leak
    By jdwheeler in forum Ferrari Talk
    Last Post: 15-03-2008, 05:53 PM
