Page 4 of 10 FirstFirst ... 23456 ... LastLast
Results 31 to 40 of 97
Thread: Another 348 Rear End Resto!
  1. #31
    749
    This is weird..Ive just returned from dropping my subframe off for blasting and at the same time took my plenum cover for their opinions on what they could do (Redditch didn't want to post my items so have had to find someone local)
    They also said that the crinkle finish was very difficult to achieve but did have a few silvers to choose from, some which looked like a textured finish, but were actually smooth. My covers at the moment are quite a dark silver from the years of grime and dirt, but is there an an actual colour to go for. I think he said they use Azko powders.
  2. #32
    749
    Quote Originally Posted by PAUL V View Post
    Sorry no only made the one for my Engine, i would remove the manifold and heat it up and undo it with some mole grips, mine came out quite easy. If you want to send me your water manifold i don't mind making you one up, however this wont be until mid next month as i am away to the USA in a few days.
    Hi Paul - Thats a very kind offer. Im in no rush as am Im getting deeper and deeper into the resto so time isn't an issue. When I get it off, I'll give you a shout and go from there. Thanks
  3. #33
    1,004
    Chances are they use the same suppliers for the powder as both companies are having problems getting the process
    right. Its to hit and miss for them to be bothered if they are busy. Mine look ok as I said before but I think the effort
    to get there wore him out. They had a lot on at the time. Ive no idea what the colour code is. Dave at Redditch may
    help you there. I don't like the idea of a smooth,shiny finish on the plenum or intake pipes. Best avoided.
  4. #34
    749
    Next couple of questions - Throttle Bodies
    Photo 1 - I want to remove the butterfly from the throttle body ready for powder coating however the screws appear to be plastic with the ends burred so as I try and undo them, they stick on the shaft. I dont want to force them in case they strip. Any tips on this one
    Photo 2 - Before I remove these bits on the side, are they strategically factory set or can I just count the winds out etc?
  5. #35
    749
    No, nor do I being truthful. They can do any of the colours in textured, but the crinkle is the issue
  6. #36
    749
    Gave the engine block a bit of a spruce up today, quite pleased with the results.
  7. #37
    1,004
    Quote Originally Posted by Quigs View Post
    You will have to remove the peened over end of the screws with something like a Dremmel grinding bit. Be careful
    not to damage the shaft. You can then refit using a high strength thread lock. I tried to find some new, correct screws for this job but was unsuccessful at the time. Just take off the smallest amount needed to remove the screws.
    When I removed the air bleed/ idle adjusters I did some careful measuring first so at least you can put them back
    where you found them. I had no issues with the idle speed on running the engine after reassembly. N.
  8. #38
    749
    Thanks Nick, just wanted to confirm I wasn't imaging it as the central butterfly operated by the vacuum has metal screws. Better break out the Dremel and micrometer then
  9. #39
    749
    Spent a bit of time on a cam cover today and so pleased with the results I don't think I'll chance getting it re-blasted / coated.
    Im so tempted to take the red off the Ferarri lettering high point
    Before
    After
  10. #40
    Apr 2013
    South Coast, Hants
    Carl
    1,475
    The condition of your cam cover, it certainly doesn't need doing. It's in great condition.
  1. Ferrari 348 engine bay and rear end restoration.
    By Pangea in forum Buyers Guides, Restorations and Running Reports
    Last Post: 08-03-2019, 07:07 PM
  2. 308 gt4 resto
    By zimm in forum Ferrari Talk
    Last Post: 18-08-2014, 10:18 AM
  3. 348 centre dash heater vent resto.
    By Pangea in forum Galleries and Members Cars
    Last Post: 22-05-2014, 01:18 AM
  4. Ferrari 348 - end of an era?
    By candellara in forum Ferrari Talk
    Last Post: 15-09-2011, 11:14 AM
  5. Replies: 16
    Last Post: 22-07-2009, 05:28 PM
