Page 2 of 2 FirstFirst 12
Results 11 to 17 of 17
Thread: Chipex Paint/chip repair
    10,847
    That looks really good. Nice job
    MalcH's Avatar
    11,549
    That does look good. I know I tried to do too much at once. Mine was more of a rash as I unfortunately witnessed a red light runner and the debris from the car in front that was hit peppered the bonnet of mine. Probably wants a repainted bonnet.
    achaddy's Avatar
    achaddy is offline Only 37 known common faults - The Ferrari 355 Club Member
    Oxfordshire
    Andy Chadwick
    1,194
    Default Chipex Paint/chip repair
    I have bought and used this kit. One thing I liked about it is it is a 1 coat paint mix so no dabbing base colour and then clear on top. Never thought it user friendly when trying to touch in chips.
    It's also not too expensive against other paint stick options. My Audi 2 coat touch up kit cost 20 and that's just 2 tubes of paint with a brush big enough to paint the whole car.
    As for the results I think it's all about practice. The theory is good and while I haven't quite mastered their method you can always build it up, flat it back slight and polish.
    From my experience I find I always seem to wash the paint out of the chip when using the blend in solution.
    Oct 2006
    Oxfordshire
    45
    I agree with you about technique. The first time I tried it I seemed to wash the paint straight out, but figured I hadn't left it long enough. Started over again & left it a bit longer, until the paint was tacky dry, then used the solution. I felt the trick was not to apply any/too much pressure with the solution. It does say in the instructions to let it do the work for you. Once I'd finished that, used the polish they supply in the kit (which appears to be similar to T-cut etc) and it bought it up well. I used my Razeglaze 55 over the top & job done!
    I've also since used the kit on a couple of scratches under my bumper after a small conflict with a speed hump. I wasn't too worried about the finish as you can't see it really, even when getting down on the floor and looking, but I'm really pleased with that result too.
    Oct 2015
    usk
    birdseye
    467
    And how about the colour match? I bought an aerosol from Halfords and watched carefully as the girl weighed out the various colours to make up the required shade only to fin on use that the shade wasnt a match. It seems that there are several rosso corsas.
    dave964's Avatar
    Jul 2011
    Camberley
    1,458
    Quote Originally Posted by birdseye View Post
    I had Rosso Corsa mixed up by Halfords - using the correct code - and it was perfect.
    I have chipex for my current car, and it's also an excellent match - but obviously you need to be choosing the right colour in the first place.
    Jul 2016
    Uk
    Mike N
    37
    You should have a sticker in the luggage space with a paint code on it. More than 1 rosso corsa etc
  1. Wheelarch paint repair - how to do it?
    By Angelis in forum Technical Q & A
    Last Post: 10-04-2008, 05:25 PM
  2. Chip your 355 for 29.95!
    By ian_uk1975 in forum Ferrari Talk
    Last Post: 03-10-2007, 02:52 PM
  3. 355 chip?
    By ian_uk1975 in forum Technical Q & A
    Last Post: 16-06-2007, 10:29 AM
  4. Chip Repair
    By Nikue in forum Car Cleaning and Detailing
    Last Post: 01-06-2007, 02:33 PM
  5. Stone chip...
    By andy456M in forum Ferrari Talk
    Last Post: 14-03-2007, 12:34 PM
