Results 1 to 10 of 20
Thread: 612 buying advice
    Shak is offline Burnt out Rover Metro Club Member
    Apr 2017
    Demus
    9
    Question 612 buying advice
    Hi there
    I need your help and wisdom.
    Been considering a 612 (need a car for 2 little people as well).Now while the 612 doesn't excite me like any of the other cars it seems to tick one of my major bucket list items i.e. to own a Ferrari.
    Ideally I would have wanted a manual but it seems these have a considerable premium over the F1 and after nearly doubling my budget couldn't justify it for a car I would use probably only 1,000 miles a year (if that).
    I have tried my best to research using search facilities both in this forum, other forums and google but not with a great deal of success. While buyer's guide for 612 is a little more sparse then other models the consensus is to buy the best you afford as otherwise it will be more expensive in the long run. Anyway what I am looking for is a some help, advice, suggestions, ideas of how to go about the whole buying process. Specific questions I have are,
    1. Irrespective of where I buy it from i.e. Private, Independent Specialist or Ferrari main dealer, I should get Pre Purchase Inspection. Who would you recommend? Also how would it work if the car is with a dealer e.g. in case they are not happy to have the car taken somewhere. Do some PPI folk travel? Or are there some dealers you would 'trust'.
    2. I have noticed that some 612 have after market modification i.e satnav, bluetooth etc. Does this make them less desirable? Personally, I would have preferred to have everything as stock but compromises will have to be made due to budget and just how old the car is
    3. Mileage - is the 612 prices a sensitive as other models?
    4. What are considered desirable features and set up. Appreciate purely subjective but again interest to hear people's thought. I seem to prefer the darker colours due to it size.
    5. While I would probably get PPI done, what are obvious checks someone can do themselves? To be clear I am not at all mechanical minded but have fairly good observational skills.
    6. I will be complying the with all the required servicing i.e. annual, major etc. Who would you recommend? I am based in London so the guess that and the surrounding areas would be the obvious catchment area.
    I will no doubt add further questions to this list but in the meantime, I would like to thank you for help and look forward to sharing my experience.
    Thanks
    19,091
    Default Welcome & good luck with your search
    London is a big place so you could be nearer someone not necessarily in London - more detail would help - not everyone is as capable with V12 as others
    Yes PPI is essential - its pointless to recommend anyone til you know where the car is as it would usually be done by someone local
    Apr 2017
    Demus
    9
    Quote Originally Posted by jos View Post
    Hi Jos,
    Thanks for the comment and definitely makes sense that the PPI would be done by someone local. My comment was also aimed at general practises i.e. is it typical for the car to go to the PPI specialist or vice versa and also if they travel to the car what would be considered reasonable
    You mentioned more detailed would be helpful, what details would thoses be?
    Thanks again
    Apr 2017
    Demus
    9
    Also would like to thank other people (hopefully you know you are!) whom I have had the chance to either speak to over the phone or via message re offering their guidance and expertise in this matter.
    19,091
    Q6 - where in London would be convenient for you ?
    Q1 - depends - sometimes dealer is happy to lend facilities for PPI othertimes car goes to PPI - cost is a few hundred quid
    10,866
    Hi Shak. I don't know a great deal about the 612 (other than they seem great value right now) but would say that many if not all indies that will do a PPI will travel to the car to do it. I'm not sure of the current going rate but I paid 200 to have my 348 inspected a few years ago, perhsps expect to pay a little more.
    Apr 2017
    Demus
    9
    Ah I see, you were referring to the servicing question. My prefereence would be 1-1.5 hrs from east london e.g. essex, kent etc. This would also include any inner london place too. If there are place a little farther out or nearer west london terrority then would still definitely look at them if the stars are aligned i.e. servicing skills, costs etc etc.
    Also thanks for the insight about PPI both in approach and indicative cost
    Apr 2017
    Demus
    9
    Hi
    Thanks for the response.
    While not the same vehicle, what information came out of the ppi for your 348 (that you found helpful/useful) and what could you do yourself first i.e. initial to guage whether that 348 was the right one for you. Curious to know the standard of a PPI as I assume they differing from inspector to inspector.
    Understand you may not know a great deal about 612 - I have found it difficuly to find a lot of it myelf - but you mention that 612 seem great value right now....in what context? Based on what they are or on what they were worth when new? An obvious crystal ball style question would be people's opinion of where they are headed - not to make money but may be to buy a better condition for the current price.
    Again thanks for getting me to think more about it!
    mon the fish's Avatar
    Jun 2013
    Aberdeenshire
    Gordon
    2,025
    I got Tim Walker to PPI my 550, for 350 IIRC. He travelled to the car for me, and I think it was a 3-4 hour round trip for him. My car was for sale at a respected indie who had no problem with the PPI.
    I didn't see the car until I'd paid for it, so I was trusting the PPI 100%. Outstanding finance, number plate transfers, the service history as well as the condition of the car were all checked and only minor things like the wiper arm alignment needing adjusting came to light. These were sorted before collection.
    To choose the car I wanted PPI'd in the first place, I scoured the web to see what was for sale. I didn't want red, or a black interior. My ideal spec was the one I bought, so I got that checked and went ahead. Most people tell you to look at a number of cars before deciding on one. This may be easy in the south, not so much for me in NE Scotland. I wasn't willing to waste time and money traipsing round looking at cars all the time when I could pay someone to do it for me.
    4 seater Ferrari's always seem value as a used car compared to their two seater equivalents. A 612 has effectively the same engine as a 550 and 575, and is cheaper than either. But I don't think they'll rise significantly in value.
    612s are one of the first modern Ferrari's, so check everything electrical works as it should. The engine should give you no problems, they're solid and understressed. Accident damage and suspension/brake wear, also clutch if it's an F1 are probably the main mechanical things to look for but the person doing the PPI will know this.
    Sent from my SM-P605 using Tapatalk
    19,091
    Service in your quadrant would probably be Grimaldi Halstead or The Ferrari Centre Maidstone - possibly Ed Biasi up near Northampton (Christian Lewis)
    It should be noted that some main dealers are very competitive and good so for example my 575 (similar running geato a 612) used to go to Carrs of Exeter
  1. 612 tyre advice please
    By hedge in forum Ferrari Talk
    Last Post: 26-01-2015, 09:46 PM
  2. Replies: 2
    Last Post: 16-04-2013, 10:27 PM
  3. 612 advice
    By danno1 in forum Ferrari Talk
    Last Post: 08-01-2010, 03:49 PM
  4. Advise on buying a 612
    By Potential612Owner in forum Ferrari Talk
    Last Post: 12-03-2008, 08:05 PM
  5. Buying advice
    By Garyh in forum Ferrari Talk
    Last Post: 06-05-2006, 10:35 AM
