Results 1 to 2 of 2
Thread: F430 Complete F1 system, Gearbox, and 1.2l Tutela CS F1 Oil
    964
    Default F430 Complete F1 system, Gearbox, and 1.2l Tutela CS F1 Oil
    Tutela, CS Speed - This is the Ferrari recommended oil for the F1 system
    Spec - SAE 75W FIAT 9.55550-SA1 CTR N F005.F98
    Ref Number 15081616
    One new 1l bottle and 1 openend bottle with approximately 0.2l left, so there is enough for an F1 fluid change (empty system takes 1l).
    18 delivered.
    F430 F1 system fully working and removed from my own 2008 F430 when I converted to a different system. The parts were professionally removed by Ed Blasi at Christian Lewis.
    This is the complete hydraulic system comprising:
    - Actuator,
    - Hydraulic lines,
    - 'Power unit' - the solenoid valve block complete with valves and sensors,
    - Pump, reservoir, and hoses - the later, stronger pump type.
    2,995
    F430 gearbox - fully working. Professionally removed by Ed Blasi at Christian Lewis when I converted to a different type.
    It is from an F1 car but if the release bearing seals are changed to the manual type (brake fluid) it can be used in a manual car.
    5,250 collected from Lincolnshire, UK.
    964
    Gearbox and F1 system sold.
    Oil still available.
  1. 355 Gearbox Oil
    By 355OXO in forum Technical Q & A
    Last Post: 23-11-2013, 11:21 PM
  2. 360 F1 Gearbox Oil?
    By Gareth in forum Technical Q & A
    Last Post: 20-07-2009, 02:55 PM
  3. 348 gearbox oil
    By jay knowles in forum Technical Q & A
    Last Post: 26-07-2008, 07:04 AM
  4. F355 Gearbox Oil?
    By F355MB in forum Technical Q & A
    Last Post: 16-12-2006, 03:43 PM
  5. Gearbox oil.
    By Fraccie in forum Technical Q & A
    Last Post: 11-09-2006, 06:37 PM
