Page 11 of 33 FirstFirst ... 91011121321 ... LastLast
Results 101 to 110 of 325
Thread: My Argento 360
  1. #101
    3,548
    Default My Argento 360
    Looking at it again......^^^^the last post is bull**** ^^^
    Can a mod delete it please? Iím outside the 20 mins
  2. #102
    Nosevi is online now There's an outside too? Where? Super Moderator
    10,982
    Done
  3. #103
    1,035
    Only just seen this thread, you doing a good job Mike
  4. #104
    3,548
    Done
    Cheers....
    Quote Originally Posted by PAUL V View Post
    Cheers Paul....some way to get to your 348 standard.
    This is the latest version of my seal drawing and as they are installed...
  5. #105
    3,548
    Good progress today.....
    Release bearing fitted.....keeping everything nice and clean.
    Iím aiming to disturb as little as possible so Iíve not changed the mounting flange, stroke pins etc but they will probably all be changed for HE items at the next full clutch change.
    Next time I will also buy the stroke pin tool (AV3048). Itís doable without but a complete PITA, particularly the top one. Proper patience test!
    New O-ring in the oil way with a smear of gasket silicon. The old one had what looked like Loctite 518 on it.
    I spend the late afternoon and evening building it all back up....
    Nothing eventful other than I think I found where the damage to one of the fuel lines came from a couple of years back.
    The gearbox mounting frame has quite sharp edges and is a tight fit past the fuel lines exactly where the cut was.
    I just protected them with a bit of tape when it went back in.
    New gearbox mount fitted perfectly with the washers. Definitely easier to change out of the car.
    Itís now really solid so itíll be interesting to see what the drive is like.
    Finally after putting everything bar the exhaust system and air box on I bled the clutch and ran it through the gears. So far no drama....
    The clutch closed position is almost as it was before I powered it down..18.03-18.07.
    Itíll be interesting to see where it settles once the engine has spun over and itís been driven.
    Apparently Shell donít sell S4 ATF in 1 litre bottles anymore so Iíll try and find some online as the local stations have none.
    Heat shields, exhaust system, air box then trim left but a long-haul trip coming up so wonít be finished super quick.
  6. #106
    3,548
    These rocked up today but the car is 4000 miles away so I canít see if they fit yet.....£260 delivered so hopefully worth it.
  7. #107
    2,746
    Reminds me of returning to the UK with a full set of Nismo / Rays wheels
  8. #108
    1,442
    so off to a local hardware shop to buy 20 cheap bolts ....... just to get "a receipt" I picked up some uprated torsion bars for a 911. They were drilled out hollow so looked like gun barrels ....... I had to endure the Spanish inquisition at customs
  9. #109
    3,548
    Iíve Sharpieíd ĎSamples not for commercial saleí onto the box.
    That might do ;)
  10. #110
    3,548
    A bit of progress coming off the back of a week long business trip to the US and staying in the garage to keep me awake!
    I test fitted 5 of the titanium wheel bolts...perfect result.
    I then spent two hours looking for some exhaust nuts that Iíd mislaid under my nose. Iíll put it down to being tired.
    Cleaned up heat shields refitted...
    Then the silencer I refurbed in the other thread following what Geoff had done.
    I intend to rebuild and refit the original
    as it is in better cosmetic condition than this one, but it will do for now.
    This silencer is off an 04 car and the outlets look a lot neater than the ones that came off. They are also rust free, so I donít think theyíve seen much use.
    2000 car left, 2004 right.
    The valve actuators just look like wastegate actuators (which they probably are).
    Gasket part number .....
    The RH heat shield above the outlets was filthy from many an F1 oil spill post top up. It took ages to get cleaned up....
    Exhaust all fitted and now off the stands and waiting for oils and the airbox, then Iíll run it up to temp and check over before boxing it up.
    Really looking forward to getting out in the next week or so. I do hope it all works.....
  2. Argento Strad for sale
    By 15hn in forum Ferrari Talk
    By steve f in forum Lounge
