Page 3 of 6 FirstFirst 12345 ... LastLast
Results 21 to 30 of 55
Thread: Advice required: 2006 Manual vs 2008 low mileage F430
    2,703
    What's the root cause mark?
    957
    The rod bolts stretch and/or the rod caps break. Said builder is of the opinion that the bolts and caps used are on the edge for a flat plane crank application with this rod ratio.
    Mike01606 is online now Nowhere to put the shopping -The Ferrari F40 Club Member
    3,486
    I've now seen four engine failures. The incidents aren't known because of fear of the cars' value being affected. The (very) knowledge engine builder I deal with has direct experience: the big ends become oval and "It only takes a few 100's of a millimeter before it fails.".
    I'm going to check mine at the 40k interval.
    There’s been a couple on FChat in the last year or so.
    As above “I’ve got this knocking noise” then “I need a new engine” then tumbleweeds......
    Should be fairly inexpensive to check and shouldn’t be a cause for concern now a known issue.
    2,703
    Wonder if the factory has enough occurences for it to be a registered issue yet and / or any upgrades took place for the 458.
    It's not something that was triggered as a known failure mode in the development program according to my sources.
    Having said that there is a dead 458 with significant engine damage that everyone is keeping quiet about.
    957
    458 rods are 3 mm longer meaning the engine has a better rod angle mid-stroke. They also have different rod bearings.
    The F430 Challenge has stronger rods and bolts.
    The rod angle/ratio would have been fully understood at design time. Either weight optimisation went too far, or the bean counters did...
    3,486
    Possibly one of the 200 V8’s covered by the crankshaft recall?
    2,703
    No the crankshaft issue was a manufacturing defect where as these guys are talking connecting rod cap bolts.
    The 458 is a bore and tolerance related issue exacerbated by a lack of use...so far there’s more to come out on that one.
    2,703
    Could be a GD&T stack-up issue which is Ferrari’s Achilles heel IMO.
    Sourcing challenge parts could well be the best route.
    3,486
    Default Advice required: 2006 Manual vs 2008 low mileage F430
    Red card shown!....I’m sat a work looking at a tolerance stack issue ATM so please can we get back on topic
    2,703
    Sorry Mike - believe me I feel for you...
  1. Really low mileage cars - don't quite get it....
    By Nosevi in forum Ferrari Talk
    Last Post: 24-09-2014, 11:43 PM
  2. What to look out for on low mileage 360
    By dermot in forum Ferrari Talk
    Last Post: 20-03-2009, 09:22 AM
  3. Very low mileage cars
    By Webber3 in forum Ferrari Talk
    Last Post: 23-02-2008, 04:48 PM
  4. Low mileage 355's
    By candellara in forum Ferrari Talk
    Last Post: 21-11-2007, 09:34 AM
