Page 3 of 6 FirstFirst 12345 ... LastLast
Results 21 to 30 of 55
Thread: Advice required: 2006 Manual vs 2008 low mileage F430
  1. #21
    2,700
    What's the root cause mark?
  2. #22
    957
    The rod bolts stretch and/or the rod caps break. Said builder is of the opinion that the bolts and caps used are on the edge for a flat plane crank application with this rod ratio.
  3. #23
    3,467
    I've now seen four engine failures. The incidents aren't known because of fear of the cars' value being affected. The (very) knowledge engine builder I deal with has direct experience: the big ends become oval and "It only takes a few 100's of a millimeter before it fails.".
    I'm going to check mine at the 40k interval.
    There’s been a couple on FChat in the last year or so.
    As above “I’ve got this knocking noise” then “I need a new engine” then tumbleweeds......
    Should be fairly inexpensive to check and shouldn’t be a cause for concern now a known issue.
  4. #24
    2,700
    Wonder if the factory has enough occurences for it to be a registered issue yet and / or any upgrades took place for the 458.
    It's not something that was triggered as a known failure mode in the development program according to my sources.
    Having said that there is a dead 458 with significant engine damage that everyone is keeping quiet about.
  5. #25
    957
    458 rods are 3 mm longer meaning the engine has a better rod angle mid-stroke. They also have different rod bearings.
    The F430 Challenge has stronger rods and bolts.
    The rod angle/ratio would have been fully understood at design time. Either weight optimisation went too far, or the bean counters did...
  6. #26
    3,467
    Possibly one of the 200 V8’s covered by the crankshaft recall?
  7. #27
    2,700
    No the crankshaft issue was a manufacturing defect where as these guys are talking connecting rod cap bolts.
    The 458 is a bore and tolerance related issue exacerbated by a lack of use...so far there’s more to come out on that one.
  8. #28
    2,700
    Could be a GD&T stack-up issue which is Ferrari’s Achilles heel IMO.
    Sourcing challenge parts could well be the best route.
  9. #29
    3,467
    Default Advice required: 2006 Manual vs 2008 low mileage F430
    Red card shown!....I’m sat a work looking at a tolerance stack issue ATM so please can we get back on topic
  10. #30
    2,700
    Sorry Mike - believe me I feel for you...
  1. Really low mileage cars - don't quite get it....
    By Nosevi in forum Ferrari Talk
    Last Post: 24-09-2014, 11:43 PM
  2. What to look out for on low mileage 360
    By dermot in forum Ferrari Talk
    Last Post: 20-03-2009, 09:22 AM
  3. Very low mileage cars
    By Webber3 in forum Ferrari Talk
    Last Post: 23-02-2008, 04:48 PM
  4. Low mileage 355's
    By candellara in forum Ferrari Talk
    Last Post: 21-11-2007, 09:34 AM
