Results 1 to 6 of 6
Thread: Clutch bearing noise on 308QV
    sweeni's Avatar
    sweeni is offline Nowhere to put the shopping -The Ferrari F40 Club Member
    Feb 2006
    Birkenshaw West Yorkshire
    David Todd
    3,492
    Default Clutch bearing noise on 308QV
    My 308 has recently returned from a long lay up (for a respray) and I now have a noise which sounds like it is a bearing on its last legs, metal on metal binding. Not loud but there in the background. If I depress the clutch pedal it disappears.
    Any thoughts lease?
    "When Lance "cries" on Oprah , spare a thought for all of those genuine people who walked away with no reward just shattered dreams. Each one of them is worth a thousand Lances"
    Mar 2017
    Ipswich, Suffolk
    Will Finch
    25
    Clutch release bearing would be my guess - just had similar issue on my F430.
    741
    Just a thought but I know 308's are prone to the friction disk binding to the flywheel from the effects of corrosion if left for a period of time, ask me how I know! It might get better if you maybe use it for a few miles before stripping it out
    sweeni's Avatar
    Feb 2006
    David Todd
    3,492
    Quote Originally Posted by Quigs View Post
    I did consider that some form of corrosion may be affecting something but Ive probably driven it around 70-80 miles now with no change. There seems to be no other ill effects that I can notice so will drive it a bit more and see if it subsides. Just waiting for a new throttle cable to arrive as the current one has long been sticky.
    741
    Just a warning though, I had to have my flywheel surface ground as a result so if it hasn't cleared, it might be worth getting a look inside
    Aug 2017
    Little Bentley,Colchester
    Eddie Walsh
    87
    Quote Originally Posted by sweeni View Post
    Any thoughts lease?
    Hi it could be the spigot shaft bearing in the back of the Crankshaft ??, Regards DM
  1. hills clutch bearing
    By MD Clutches in forum Ferrari Talk
    Last Post: 26-08-2015, 03:07 PM
  2. 355 clutch and release bearing
    By Wrighty1111 in forum Technical Q & A
    Last Post: 17-08-2011, 11:30 PM
  3. 348 clutch/bearing rattle
    By RacingSnake in forum Technical Q & A
    Last Post: 16-10-2008, 08:44 PM
  4. 348 Clutch Release Bearing
    By Chris F348 in forum Ferrari Talk
    Last Post: 20-05-2006, 03:07 PM
