Hello all, newbie here seeking help!
I have a 430 coupe manual which unfortunately spends a good deal of time in storage until I am brave enough to tell the wife I own it!
It comes out to lay a couple of times a year and has historically been faultless but last year I picked it up from storage where it is on a trickle charger, cold started perfectly with that flare of the Revs and high idle for a while. Drove 50 miles and pulled in for fuel. Went to restart and it barely caught on the starter, certainly no flare of the revs. Idled very low indeed, close to cutting out. Then seemed to clear and all carried on as usual.
At the annual service in October last year I explained the symptoms to dealer and we decided to replace the plugs (a year early).
Unfortunately no change. So this year we have replaced the battery, and again the problem is still there.
I have put the car away for the winter now (dk engineering) but knowing something is not right is troubling me!
On Saturday I started the car from cold and it was fine, drive 50 miles, filled up with fuel to put away for the winter and it really really struggled to start, even cut out. Then it cleared. I drove a mile down the road from fuel station to the storage facility, turned it off then went to demonstrate the problem to them, pressed the start button and it started perfectly!!
Any thoughts / ideas? Could it be intermittent problem with starter motor?
Thanks in advance
Thanks in advance
