Page 2 of 2 FirstFirst 12
Results 11 to 18 of 18
Thread: White dust in 360 engine bay
    Hud's Avatar
    Hud is offline Post whore with no life, no friends, and a problem fitting into normal social circles Club Member
    Rural Northamptonshire
    Rob
    16,667
    Quote Originally Posted by Brian (Rifledriver)
    The insulation from the stock mufflers do that. It will dust the entire engine compartment.
    anything to cure it?
    ric355's Avatar
    ric355 is offline Nowhere to put the shopping -The Ferrari F40 Club Member
    Richard
    3,438
    Quote Originally Posted by Hud90n
    Replace with a Tubi or Capristo, and rip the cats off it while you're on.
    Hud's Avatar
    Rob
    16,667
    Quote Originally Posted by ric355
    mmm.Now thats a genuine reason for doing it - pretty sure i can convince the mrs now - cheers ric.
    Iain
    7,173
    Been getting alot of white powder settling on the engine after use. Spoke to graypaul and they tell me its quite a common thing and come from some of the heat protective wadding in the engine bay, nothing to be concerned about. Anyone else had this problem?
    On a 355 it would tend to indicate the headers had blown through & would need fixing pronto before valves start burning. Not sure if the 360 is prone to the same issue - probably worth a good poke around.
    I.
    12 Cylinder Village
    Si
    13,431
    and theres me thinking you sneezed whilst snorting coke therefore overfilling the engine oil
    California
    Brian Crall
    138
    Quote Originally Posted by Iain
    I.
    You are correct but the 360's really haven't had a header problem. Almost every 360 with a stock muffler has had this problem given enough time.
    The only cure is a different muffler(Tubi).
    Rick
    1,842
    Haven't got the problem with the Tubi - you now it makes sense !!
    How does the white dust get in the engine compartment if it's coming from the exhaust ?
    Rick
  8. #18
    California
    Brian Crall
    138
    The muffler is a big insulated can. The part you see is the outer layer, like a Thermos bottle. There are seams and the insulation leaks out of them. Look at the muffler cold and look again hot. You will see witness marks that show about 1-1.5 cm expansion width wise. During the expansion/contraction cycle the insulation works out between the expansion joint.
    Quote Originally Posted by Bromers
    Rick
