Results 1 to 7 of 7
Thread: rubber seals & trims
    The Isle of Man
    David
    3,311
    Default rubber seals & trims
    The rubber seals (doors, bonnet, engine cover, targa roof etc) on gina are looking a little tired and discoloured.
    Is there a product out there which will revive the above ?
    Many thanks for your anticipated, abundant assistance.
    , d
    12 Cylinder Village
    Si
    13,431
    Quote Originally Posted by F308 MAN
    , d
    If there is d you'll probably find it here and its just up the road from me
    http://www.woolies-trim.co.uk/
    in someone elses garage
    1,985
    , d
    Dave,
    Zymol have a product for this called oddley enough "seal".
    I used it on a mini i restored last year , it soaks into the seals as opposed to just sitting on top of it and making it look new.
    I used it on both the door/boot seals and on the window seals ,
    The windows seals in particular were very brittle , so i applied it 3 or four times and it did the trick.
    The Isle of Man
    David
    3,311
    Quote Originally Posted by Dave Zymol
    Dave,
    many thanks, simon and dave ... you're stars.
    huddersfield
    steveb
    930
    try rubbin some vaseline on it did my roof seal and then light coating of silicone,now look good as new and now sqeak free roof
    Herts
    Marc
    1,167
    , d
    Dave,
    I bought this stuff from these guys and it worked ok - I need to apply a number of coats more to get the wet dog nose effect tho..also better to do it outside on a sunny day for the seal to dry or you get the greasy impressions on the inside of your windows - annoying when the seals are the last thing you do in a marathon cleaning session!!
    Expensive but worthwhile.
    http://www.premierbodyshops.co.uk/zy...eding/Seal.htm
    The Isle of Man
    David
    3,311
    thanks marc ... it will be ordered as soon as i have saved up the 20+
    , d
