Page 2 of 4 FirstFirst 1234 LastLast
Results 11 to 20 of 38
Thread: alloy refurb course
    12 Cylinder Village
    Si
    13,431
    Quote Originally Posted by GrahamS View Post
    Yes because you're also balancing the tyre, not just the wheel, so once you take it off you have to start again
    But the tyre has'nt changed
    GrahamS's Avatar
    Oct 2005
    NW Kent
    GrandmasterG
    23,649
    Quote Originally Posted by barabus View Post
    No, but it's exact position on the wheel has. Tyres aren't perfectly weighted.
    in someone elses garage
    1,985
    Quote Originally Posted by col68 View Post
    Dave, Looks good....can the tyres be mounted straight away or do you have to allow the laquer/paint to fully harden?What paint you spraying with....water based?
    So your going to need a bigger Van, compressor, wheel changer and balancer, paint and materials etc.
    Anyway good luck with it, be good to have everything under the one roof
    Yes the tyres can be remounted , the whole idea of the UV lacquer is that it cures within 10 minutes and sets rock hard
    I've got both water based and solvent , but probably use the water based , also got the compressor and guns , minature air D/A sander and polisher , heat guns , UV lamp etc etc ,
    Got a bead breaker coming
    I think it will be good to be able to offer the complete detailing package to customers instead of sending them away for wheels and dents
    Is there any need to re-balance as long as the weights are on the inside and not taken off
    I haven't got (can'y afford ) a balancer yet , so would recommend a trip down local tyre place for balancing afterwards
    1,985
    You could go mad with equipment
    The first thing is a self contained spray booth / extractor , the second is a curing oven , inside is a UV lamp , this thing fully cures the lacquer in 2 minutes
    12 Cylinder Village
    Si
    13,431
    Dave what do you do if there's a chunk missing from the rim, can you fill it?
    1,985
    yes mate , as long as it's not to big or a split in the metal
    If the wheel is genuinely fubar'd then its a case of replacing it
    Sep 2006
    Chandlers Ford
    Phil Worrall
    1,655
    Well Dave, my tyres are off and the wheels are bare ready for your process.
    I have metal valve stems do you want me to remove these as well?
    Those wheel you posted look stunning. Are the silver 'chrome' effect ones hard keep clean?
    Phil
  8. #18
    1,985
    Quote Originally Posted by philworrall View Post
    Phil
    If you can get the valve stems out that would be great , they're all easy to keep clean , its a very hard setting lacquer , which is fine if you use wheel acid etc it wont go dull like the smart repair systems
    I'll be in touch over the next few days to get you booked in
  9. #19
    Apr 2006
    Whyteleafe
    Simon Stroud
    1,311
    Dave,
    Looks stunning, if u want an edge over the competition, most only do the outer face, personally i feel it is better when the inside face is done also on the inner rim.
    How much for each wheel? 30 quid?
  10. #20
    1,985
    Quote Originally Posted by 355OXO View Post
    Dave,
    Already thought of that one mate , so will be doing inner rims aswell
    30 you know swearings been banned
  1. Replies: 13
    Last Post: 25-04-2008, 09:17 AM
  2. Mobile Alloy wheel refurb company
    By sjw ferrari in forum Ferrari Talk
    Last Post: 31-03-2007, 09:23 PM
  3. replacement 360 front alloy
    By Timmmmmmo in forum Ferrari Talk
    Last Post: 11-09-2006, 10:15 PM
  4. 456 wheels - alloy wheel refurb advice
    By W100001W in forum Technical Q & A
    Last Post: 27-01-2006, 08:40 PM
