Page 4 of 4 FirstFirst ... 234
Results 31 to 39 of 39
Thread: Carcoon - Impression of a new owner
  1. #31
    11,032
    Quote Originally Posted by MalcQV View Post
    Maybe, the zip start/end is in the far corner of the garage, actually the hardest part to reach. It will be a right pain to open and empty.
    We are getting towards Spring/Summer now so I will re-address this in in October at which point my car may have moved out from it's current location
    Always been told there's no such thing as a stupid question, but this might be one. Why not just turn the carcoon round so the zip's at the other end? Use an extention lead to plug it in, perhaps? Kind of think I'm missing something though.....
  2. #32
    Murph7355's Avatar
    Here there and everywhere
    Murph
    14,313
    . . 2 minute job.
    Depends where your garage is, how often you go to it and if your volumetrics apply
    Not a garage, but the dehumidifier in my old shack used to fill the tank in a day (think it was a 5l tank, maybe smaller). I used to forget more often than not, though the condensation on the windows was a handy "alarm"!
    I ended up drilling a hole through the wall and running a condensate pipe to the other half's veg patch
  3. #33
    MalcH's Avatar
    11,586
    I would say it is a rather obvious one myself . I set it up this way at first and it of course means the zip is the most accessible . However the connection for the charger and fans foul the garage door (the garage is actually too short for my Carcoon). Due to cupboards at the rear of the garage it holds the Carcoon away from the back wall and allows the fans to breathe easily
    If it was my garage and not my Dad's I would rearrange stuff but I do not want to push it. I currently (including the daily) have two cars on his drive and the F355 in his garage. With their two cars it is getting a tad crowded.
    I'm old and due to my tightness (should have been born in Yorkshire ) I decided to rent off my parents rather than pay someone else's mortgage (actually I'm paying the Ex's mortgage but I will one day get that back).
  4. #34
    11,032
    Quote Originally Posted by Murph7355 View Post
    Guess that's the advantage of a Carcoon. As it'd an almost sealed environment, once you've got the moisture out, only a very small amount goes in so it takes much longer for your tank to fill.
  5. #35
    11,032
    BTW, does anyone have a picture of how they've got it rigged into the roof? Is it just tied or is there a pulley system involved?
  6. #36
    Earth
    19,734
    Here you go.I just tie it to some eyelets in the roof beams
  7. #37
    11,032
    Quote Originally Posted by stevew View Post
    Cheers Steve, just wasn't sure if you needed to pull it up more to stop it sagging. My garage is narrower than yours so I won't get it pulling diagonally as much. Will just have to give it a go. BTW in case you didn't see on the other thread, cheers for the replacement fan unit. Getting it in the post in less than 24 hours from saying one of mine wasn't working quite right was a tad impressive. Great service. Other one is on it's way back to Carcoon.
  8. #38
    Earth
    19,734
    If need be sometimes I undo the rope at the eyelet and pull the Carcoon up a bit further if I need it out of the way.
    Glad the fan got there OK.Did you swap it over OK ??
  9. #39
    11,032
    No snags at all. Carcoon sent the whole unit with filters in place to make life easy. Took about 2 minutes to swap over.
  1. Carcoon
    By 355Chris in forum Ferrari Talk
    Last Post: 15-01-2011, 09:14 PM
  2. CS first impression of club
    By photoman1963 in forum Lounge
    Last Post: 16-09-2009, 07:43 AM
  3. Carcoon
    By Radders in forum Car Cleaning and Detailing
    Last Post: 24-02-2009, 03:37 PM
  4. Replies: 6
    Last Post: 26-07-2007, 05:40 PM
