Results 1 to 5 of 5
Thread: Ferrari F430 cracked wheel. Repair or replace?
    Dec 2010
    Me
    22
    Default Ferrari F430 cracked wheel. Repair or replace?
    Hi.
    So my F430 has a cracked front left wheel rim. The crack is about an inch long and is right on the edge of the inside of the wheel. I initially thought it was the tyre but when the tyre was taken off the crack was rather obvious. Since the tyre has been put back on the leak is so fast that I cannot drive the car or keep the tyre pumped up (goes down in around 10 minutes)
    Just wanted to get a feel for peopleís opinions before going out and blowing a packet on a new rim. Would you repair it? If so, where would you go? (I live in Cheshire if anyone has a recommendation). If you wouldnít repair it then why not?
    Thanks in advance for your opinions.
    Cheers!
    Sheep
    3,556
    Try The Wheel Restorer in Wrexham which isnít too far.
    Iíve never used him personally but I believe he is very good.
    He repaired a guy at works 430 wheels and did a great job. If heís painting them heíll probably want to do the front and rear on the affected side.
    M
    1,442
    I would replace as it very difficult to mend a crack on some alloys. That "repaired" crack could burst off the rim and give you a blow out ........ not a problem on a sit on mower but on a fast car do you really want to risk a blow out at speed ???
    Also the by the time you add the cost of fixing the crack along with having the reminder of the wheel checked for other hairline cracks and a repainting job a replacement wheel might not be much more expensive ??
    119
    Presumably you are thinking a welded repair. Problem is the end of the crack would be a high stress point or raiser. If the weld doesnít go to the end of the crack then it might propagate further causing a failure when driving.
    Mar 2006
    Bucks
    cgt
    6,254
    Is it a 19'' Challenge rim? My car developed a hairline crack on one of the spokes. Scarily, I only discovered it after getting back from a Euro trip that included some high speed stuff in Germany.
    In the interests of safety I would just buy a new one. Sure, it probably can be repaired but safety first.
  1. Damaged wing badge on 360 - repair or replace?
    By Iipboss in forum Ferrari Talk
    Last Post: 06-09-2013, 11:13 PM
  2. F430 Cracked Manifold ??? What 2 do now ???
    By sean8696 in forum Technical Q & A
    Last Post: 13-12-2012, 11:14 PM
  3. Cracked 430 wheel
    By mylop in forum Ferrari Talk
    Last Post: 12-09-2012, 08:00 PM
  4. Cracked wheel-centres
    By smythersyoufool in forum Technical Q & A
    Last Post: 14-11-2011, 08:11 PM
