Results 1 to 5 of 5
Thread: 308 - 1st gear not selecting
    sweeni's Avatar
    sweeni is offline Kid's bed - The Ferrari F50 Club Member
    Feb 2006
    Birkenshaw West Yorkshire
    David Todd
    3,540
    Default 308 - 1st gear not selecting
    Hit a bump in the road very hard recently and since then have had an intermittent problem selecting 1st gear.
    The lever goes in no problem but on lifting the clutch pedal sometimes there's nothing there.
    Any thoughts on what has been damaged?
    "When Lance "cries" on Oprah , spare a thought for all of those genuine people who walked away with no reward – just shattered dreams. Each one of them is worth a thousand Lances"
    12,015
    Could just be the linkage has been knocked out of adjustment so when the gear lever is all the way in it's not moved the linkage enough to select the gear. Have you tried removing the gate and seen if it goes in if you move the gear lever further than the gate would allow?
    Not familiar with the 308 setup but I've seen them adjusted on 348s which has cables and 355 which has a solid rod (which I believe the 308 has?) and neither is that tricky to do.
    sweeni's Avatar
    Feb 2006
    David Todd
    3,540
    I’ll try that, cheers
    Bucks
    cgt
    6,324
    I had exactly this on a 360. Thought I was looking at expensive gearbox failure, it was just the cables needing adjustment
    Sent from my SM-G988B using Tapatalk
    francisn is offline Post whore with no life, no friends, and a problem fitting into normal social circles Admin dude
    S. England, but Scottish!
    Francis Newman
    17,069
    The 308 has rod linkage. The linkName:  308_gear_linkage.jpg
Size:  82.5 KBage is exposed at the back of the flat underfloor. There is an adjuster held in the correct position by left and right hand threaded nuts which tighten against the adjuster to hold it in the right position. I have twice had that slip which meant I lost 1st and reverse (1st gave me 3rd and reverse gave me 2nd.
    Dave, give me a call and I'll talk you through it.
  1. Manual 360 gear shift issue (3rd gear crunch)
    By Luke_sedz in forum Technical Q & A
    Last Post: 25-12-2014, 12:02 AM
  2. Mondial t and selecting 5th gear
    By My First ferrari in forum Technical Q & A
    Last Post: 30-03-2012, 10:15 PM
  3. Difficulty selecting gear after starting
    By zuby84 in forum Technical Q & A
    Last Post: 12-07-2010, 01:31 PM
  4. 355: gear ratios and max in gear speeds
    By madras in forum Technical Q & A
    Last Post: 01-12-2007, 03:15 PM
  5. F355 - Sticky Gear Box in 2nd Gear
    By donniemac in forum Ferrari Talk
    Last Post: 01-04-2007, 12:58 PM
