355: Changing rear dampers
Ric why did you compress the spring before removing the damper assy m8 theres no need, do it on the bench,and those spring compressors are a bit ify m8,borrow mine next time there built for that job and wont scratch the powder coating off the spring m8.
I wasn't sure whether the damper was at full extension with the suspension unloaded, so compressed it first to make sure it didn't spring apart when I loosened the bottom bolt. Will know for next time :thumbsup:
