A delivery of parts like this can only mean one thing. Few other jobs to attend to while its out of the way.. Mainly. cosmetic. More pics to come as I get into it.
+1
Where did you get the water pump from?
Really look forward to seeing this.
About how long did t take to get the engine out, Nick?
I pulled it over a couple of days Pete, but not on it full time. Some work on a ramp first. Oil drain, cables, some of the mounting bolts etc. Stuff that would be tricky on the floor. You could probably get it out in a morning if you wanted too.. Im in no rush though.
if you put a hills water pump in, check the seals and that the mating surface is flat. dl put a new one in and it leaked. they had to do another engine out, so now refuse to fit hill pumps.
be worth checking with them what pressure tests they do on them before shipping; just to convince yourself its all good.
Much better quality item than the plastic:thumbsup:
Looks much better, Nick :thumbsup:
Putting in new 'foil' is something I had done during an engine out. Thing is when you brighten up one area it can sort of show up another so it leads on to other things. For me next it was replacing the foam under the engine cover which really got shown up when the front wall of the engine bay looked shiny and new. Don't know how firm you are on original look but I replaced the standard brown foam (which I think you had before if I remember earlier pictures?) with black. It's not original but it really lifts the engine bay I think.
Mind if I post up a pic? Don't want to 'hijack' your thread but it does make the engine bay look different.
Time to get loads of parts powder costed and plated; as Pete says, once you start….!
