I've not had time to update over the weekend but I've made some really good progress......
Yesterday I started to build the motor back up as the paint was fully cured.
The crankcases haven't been split this time. The bottom end appears to be in good condition and I believe the 15k miles on the odo is genuine.
I put some two stroke oil on the big ends then lubricated the new little end bearings.
The piston rings had been fitted to the pistons by Paul so I lubricated them with two stroke oil along with the barrels and gudgeon pins. I fitted the inner circlip then fitted each piston to the conrods and then the outer circlips. Using paper towel in the crankcase opening to stop anything dropping inside.
The pistons have locating pegs for the rings to prevent the rings rotating in the groove and the ends being caught in one of the ports. It is important that these are lined up before attempting to fit the piston into the barrel to prevent breaking the rings.
A new base gasket then the barrel was slid over each piston. I didn't use any sealant, grease or oil on the paper gaskets.
Both pistons and barrels fitted. All hopefully the correct way around!
Finally for the top end was fitting the head using the very expensive genuine head gasket.
The head bolt torque sequence is marked on the head and I torque each one up in about 5 increasing settings up to 17.4 ft/pounds.
I put the inlet reed valves in before the motor was installed. These are a non return valve to control the 2 stroke induction. I hadn't touched these at all other than a quick inspection.
The complete engine.......
