Just watched all 10 episodes straight as not had time until now.
Anyone with a gt4/308/328 know how challenging they can be with space and working underneath and in cramped spaces so I take my hat off to you Scottie.
Keep positive bud, you've made some big positive strides from episode 1 to 10
You now have positive spark across all eight, overcoming bad no1 lead and dodgy coil pack wiring sorting crank sensor/TDC 5-8
Fixed slow return of Metering unit
Fuel leak sorted
You have proven fuel flow to fuel injectors.
Your one belt/tension look good on the rear bank, awaiting to see forward bank,
Compression test is a big worry as others have said.
Let's see what the TDC marks show on forward cover ( has it slipped a tooth? Has is bent a valve)
Keep positive Scottie and keep sharing your journey with us, I know there are many many people glued to this thread and awaiting your next episode, good luck from a 328 owner.
I know you have another donor car in the garage but if you need a known good spare part to test with, just ask out loud as many of us owners have lots of spares lying around you could borrow if you need to.
Keep the updates coming
