Hi Folks,
Just had the geometry and ride height done by Damax Engineering at Brackley, exec summary, superb!
The front (and rear it turns out) was very low due to tired and sagging springs. Net result being it was relatively easy to catch the front wheel arch with the tyre when on full lock and on a compound gradient for example reversing up a steepish drive. Not really a catastrophic problem as a bit of wood and a hammer with a few sharp blows can straighten out the pulled down wheel arch return.
Replaced parts are 4 off suspension springs, 8 off rubber spring seats (no images but from the main dealer), top and bottom for each spring.
When setting the ride height the spring platforms need to be wound up/down as appropriate, this can be a problem as they seize resulting in the platforms to be cut off. Mine where fine as the all dampers were changed 6 years ago
These are my old springs…..
And these beauties are my new (to me, ex Mike M’s 360, thanks Mike
) springs….
Regarding the geometry, Robin from Damax, describes it as the ‘fast road’ set up. Added a bit of toe in at the back to settle the rear a bit on the motorway. It is noticeable, previously I was constantly dialling in correction following by counter correction. However now, none of that, it’s just completely stable, feels great! I’ve not explored the turn in on a fast A-road as yet but all indications are positive.
I’m off to Wales with the Cotswold group next week so I’ll get plenty of opportunity to get a good feel for it.
Ride height approx figures, front lifted 20mm, rear 10mm.
Just filled up on the way back from Damax, latest MPG figures, 24.7, pretty good and pretty normal for my 360
